Home » Audio » Speaker » MTM horizontal arrays
Re: MTM horizontal arrays [message #61598 is a reply to message #61593] Tue, 22 December 2009 20:28 Go to previous messageGo to previous message
justinc is currently offline  justinc
CTC spacing will be too much horizontally for the Yag tweeters you would need to crossover around 1000hz. Ive used the dayton version PT2 with the dcx2496 and they really cant xover any lower than 1800hz with 24db linkwitz and that is pushing it. For the price If you wanted to do mtm i would send the peerless back and get the dayton nd90 which are cheaper and would work extremely well in that type of configuration. If you want to keep the peerless then just do a single column of each.
Previous Topic: Re: New Scan-Raal arrays
Next Topic: Finally Building Full Range Single Driver Speakers
Current Time: Sun Nov 15 22:45:11 CST 2026
