Home » Sponsored » Pi Speakers » 4 Pi and 7 Pi bass response- More similar or different? (4 Pi VS 7 Pi )
| Re: 4 Pi and 7 Pi bass response- More similar or different? [message #61568 is a reply to message #61567] |
Thu, 17 December 2009 09:44   |
To me, they definitely sound more alike than different. All my speakers have basically the same tonal balance, and they're all designed to generate a uniform pattern. They all use the same tweeters and woofers, at least in "families" - three π and six π have the same woofers, four π and seven π do too. So when you compare, say a four π and seven π with JBL 2226 and DE250 drivers, you have two speakers that sound very much alike. They're exactly the same above 2kHz and depending on placement, exactly the same from 50Hz to 200Hz too. The only real difference is between 200Hz and 2kHz. Of course, that's a real important region, arguably the most important one.
To me, the π midhorn loaded with the Delta 10 has a real SET-like sound whereas the direct radiating 2226 sounds more like a very accurate FET. Without analyzing distortion or spectral balance, that's how I'd best describe them. The 2226 is very clear sounding when run through the midrange, no hint of breakup or anything like that. But the midhorn sounds silky smooth. Both are actually very low in distortion and smooth in response, so neither is a clear "winner" in terms of either metric. Both are excellent.
Remember too, the placement environment. That's actually the biggest thing, in my opinion, to influence the sound. Do a little experiment: Take a radio or speaker and listen to it when it is sitting out in the open, radiating into freespace. Now walk with it while still playing and sit it right next to the wall, perhaps on a window sill facing you. Listen to the difference in sound as you get close to the wall. Now take the same radio and sit it in a trihedral corner. Hear the big difference in sound? It gets louder, its tonal balance changes and even the ambient room "echo" is different.
When a speaker is put in the corner, it is louder overall and usually sounds like the bass is a bit more prominent. This is all a result of directivity, as the sound coming from the speaker is forced into a pattern set by the walls. It cannot radiate omnidirectionally, even at low frequencies, because the wall angles force it into the room, just like a horn. The smaller the speaker (baffle), the more pronounced the effect because on larger speakers, the baffle itself limits the radiating angle to at least half space, the larger the baffle, the lower the frequency before it becomes omnidirectional.
The repercussions of this are profound. What it means is that when a speaker is designed to be placed in the corner, it should be voiced to compensate for the spectral shift that happens when placed in the corner, i.e. slight tilt upward in the bass. It also means that the sound at very low frequencies will have constant directivity all the way down, to the limits of the room. The room is the largest acoustic feature in the listening envirnoment, and you're usually "fighting it" to get response right. But in the case of the π cornerhorns, it becomes an advantage. Most modern (waveguide and) matched-directivity two-way speakers can only provide constant directivity above 2kHz but the π cornerhorn is CD fully a decade lower, all the way down to below 200Hz, limited only by the room modes below the Schroeder frequency.
By: tom-m on Thu, 17 December 2009 18:32
By: tom-m on Fri, 18 December 2009 09:51
By: tom-m on Fri, 18 December 2009 16:52
By: tom-m on Mon, 28 December 2009 13:00
By: feket663 on Sun, 27 December 2009 11:02
By: feket663 on Sun, 27 December 2009 14:53
By: feket663 on Mon, 28 December 2009 14:56
Cornerhorn Ruminations
Room Treatments
By: tom-m on Wed, 13 January 2010 23:22
seven π photos
By: tom-m on Fri, 15 January 2010 15:31
By: tom-m on Fri, 15 January 2010 22:01
Cornerhorns and constant directivity
Crossover considerations - power handling, frequency, slope, etc.
Current Time: Thu Nov 05 22:52:20 CST 2026
