Home » Audio » Speaker » Wardsweb DIY horns (If you can't find it, build it.)
Re: Wardsweb DIY horns [message #61491 is a reply to message #61490] Tue, 01 December 2009 15:32 Go to previous messageGo to previous message
wardsweb is currently offline  wardsweb
Depending on your wood or veneer you may want to use a sanding sealer first. It will keep you from having to use so many coats to just fill the grain of the wood. A high gloss (piano) requires a glass like surface without voids or waves. Once it is sanded to 1000 grit you then polish it with something like 3M Perfect It. Its like buffing out an automotive finish.
Previous Topic: PROJECT: 200 to 900 Hz -- a successful solution
Next Topic: What Exactly Is A Waveguide?
Current Time: Sun Nov 22 05:45:41 CST 2026
