Home » Sponsored » Pi Speakers » Don't forget to check under the hood
Re: Don't forget to check under the hood [message #61473 is a reply to message #61471] Wed, 25 November 2009 15:50 Go to previous message
Wow, what a deal! That must have been frustrating.
Do you tin the wires before inserting them? Seems like lots of stuff has those spring loaded connectors but I've never had trouble with them. The ones that bug me are the ones you have to screw down and tighten. Seems like those always come loose after a while.
I agree with Matts though. Anywhere there is a mechanical connection, you have a potential problem. I used to always avoid them, and solder everything instead. But I stopped doing that a long time ago, because I like the serviceability of having a quick connect of some sort.
Previous Topic: 3pi Plans
Next Topic: DI-matched two-way loudspeakers
Current Time: Fri Nov 27 20:38:09 CST 2026
