Home » Audio » Speaker » Going without a subwoofer.... even with smaller drivers? (what to expect regarding bass output versus total # of small woofers)
Re: Going without a subwoofer.... even with smaller drivers? [message #61422 is a reply to message #61414] Fri, 20 November 2009 06:07 Go to previous messageGo to previous message
GreggoEggo is currently offline  GreggoEggo
Thanks for weighing in Rick... The more I have looked around for info on this the more I am convinced I have to move up to a 7 inch frame driver so that I can use DSP eq to manage things but hopefully have much less cause for concern about pushing the drivers too hard, even with 18 per side.
I don't get the warning abou the neo3 however, unless this has to do with your observations around dispersion (I am guessing in the horizontal plane but perhaps you are thinking vertical). Looking at what I percieve to be the starting point of the challenge, CTC horizontal spacing between the two woofer lines on each side of the tweeter, a tweeter flange width of 2.6 inches seems pretty darn attractive compared to the other ribbon/plannar options out there. It seems that most who go with a planar choose the neo8 for the lower crossover point and narrower vertical dispersion to help manage lobe/combing in the vertical plane. Still researching.... and someday early next year I will start testing.
Regards,
Greg J.
Previous Topic: vitavox
Next Topic: PROJECT: 200 to 900 Hz -- a successful solution
Current Time: Tue Sep 22 23:10:51 CDT 2026
