Home » Audio » Speaker » driver mounting -- outside or inside of baffle.
Re: driver mounting -- outside or inside of baffle. [message #61354 is a reply to message #61353] Sat, 07 November 2009 22:12 Go to previous messageGo to previous message
If the drivers would be used at higher frequency, the mounting might matter. Both because of the distance to the listener making a slightly different flight time and because of the edge causing reflections and diffraction. But at the midrange frequencies you're talking about, wavelengths are between about two feet and six feet long, so the extra (less than an) inch of path length difference will hardly matter, and the thickness of the edge is acoustically so small it's transparent. In this case, you can probably make the choice of whichever is more aesthetically pleasant to you.
Previous Topic: Tympany lat 500"s
Next Topic: Center Channel to go with my ART Arrays
Current Time: Mon Nov 02 06:37:03 CST 2026
