Home » Audio » Speaker » Horn Loaded woofers vs Line array woofers Question
Re: Multisub explained [message #61222 is a reply to message #61215] Sun, 18 October 2009 15:43 Go to previous message
Marlboro
This schroeder frequency stuff is a little bit over my head. And adding more woofers around the room is simply not possible in this room due to other stuff that is there. While I was given the room for music, I don't have total control of it, and I have to continually be removing things that the Wife has put in front of the speakers("They're so tall why does it matter if anything is in front of the few speakers at the bottom?").
Anyways Linkwitz(http://www.linkwitzlab.com/rooms.htm) has a discussion of room acoustics and talks about the Schroeder frequency too. Using the chart for lively rooms, and the volume and floor area it looks like the schroeder should be around 150, so I moved my crossover from 165 to 150 to be closer to the frequency. If I take it too low the region around the cross will get pretty mushy for the midranges and they will become mud-ranges.
I'm still working on understanding your comment.
Previous Topic: Horn Loaded woofers
Next Topic: Hornresp
Current Time: Tue Oct 20 18:18:55 CDT 2026
