Home » Audio » Speaker » Horn Loaded woofers vs Line array woofers Question
Re: Horn Loaded woofers vs Line array woofers Question [message #61210 is a reply to message #61208] Sat, 17 October 2009 23:25 Go to previous messageGo to previous message
That's been done, as you saw. Naturally, it forms a more complex system, with two horns separated by some distance and driven out of phase from a common diaphragm. Another similar derivative is the back horn or scoop, which horn-loads the rear and has the front of the driver exposed to allow direct radiation. This is common in single driver loudspeaker designs and was also common in prosound horns a couple decades back. The so-called tapped horn is another derivation of that principle.
Previous Topic: Horn Loaded woofers
Next Topic: Hornresp
Current Time: Tue Oct 20 18:19:45 CDT 2026
