Home » Audio » Speaker » Horn Loaded woofers vs Line array woofers Question
Re: Horn Loaded woofers vs Line array woofers Question [message #61208 is a reply to message #61206] Sat, 17 October 2009 14:33 Go to previous messageGo to previous message
Marlboro
OK.... Stupid question.... since I know nothing about horn design.
What would happen to the sound if one used one woofer but two horns: one that goes off toward the upper half of the woofer, and one that goes off toward the bottom of the woofer? So you end up with two mouths but only one woofer.
ie: http://www.frugal-horn.com/spawn.html
or
http://books.google.com/books?id=y0d9VA0lkogC&pg=PA512&lpg=PA512
Previous Topic: Horn Loaded woofers
Next Topic: Hornresp
Current Time: Sun Nov 22 06:15:17 CST 2026
