Home » Audio » Speaker » Horn Loaded woofers (finding the right woofer)
Horn Loaded woofers [message #61204] Sat, 17 October 2009 10:00 Go to previous message
Marlboro
Bill Fitzmaurice and maybe Wayne Parham have plans for building horn loaded woofers.
Bill has made it clear in his own comments on the PE forum, and perhaps on his own business forum somewhere, that certain woofers are better designed for use with a horn loading than others.
You can look at one of the Q measurements and determine whether the woofer is better for acoustic suspension, bass reflex, or open design.
What parameters do you have on a woofer that determine whether its suitable for a horn loaded design? I have a 15mm xmax poly prop woofer which would probably do better horn loaded so that it could keep up with my giant line arrays, but i don't know if its suitable.
Marlboro
Previous Topic: Slot loaded woofers
Next Topic: Horn Loaded woofers vs Line array woofers Question
Current Time: Tue Oct 20 17:28:19 CDT 2026
