Home » Audio » Speaker » Slot loaded woofers
Re: Slot loaded woofers [message #61198 is a reply to message #61193] Fri, 16 October 2009 20:25 Go to previous messageGo to previous message
Will you be running push-pull drive to reduce distortion? I would, if you can get it to fit right, because I think it's one of the best ways to reduce distortion at VLF frequencies. Of course, the distance of the slots may reduce the frequency where the distortion cancellation takes place, making it less effective at higher frequencies. But I certainly think it's worth doing. This is one of those things that measurements would tell the tale best.
Previous Topic: Dedicated horn loaded mid -- big disappointment.
Next Topic: Horn Loaded woofers
Current Time: Fri Nov 13 06:01:53 CST 2026
