Home » Audio » Speaker » Slot loaded woofers
Slot loaded woofers [message #61193] Fri, 16 October 2009 01:56 Go to previous message
Bellini is currently offline  Bellini
I am working on a three way design to be used with subs for band PA purposes. I want the box to be as compact as possible. Each cabinet will contain 2x Eminence Kappalite 3015 woofers, 2x Eminence Delta pro 8B Midrange drivers, and a 1 inch compression driver on a small 60x40 horn. My desired crossover frequencies are: 400Hz between the lows and mids, and 3KHz between the mids and the highs. The enclosure will be vented, and I will need it to play down to just 70Hz. I realized that I could make the cabinet fairly short and narrow by slot loading the woofers. I would use two slots, one at the top, and the other at the bottom of the cabinet, similar to what Renkus-Heinz did with some of the cabinets in the CT line. http://www.renkus-heinz.com/loudspeakers/series/Legacy_Loudspeakers/ct_install/images/hi_res/ct7215_photo.jpg
Does anyone see any possible problems with this arrangement for the woofers that would make it not worth trying?
Thanks,
Bellini
Previous Topic: Dedicated horn loaded mid -- big disappointment.
Next Topic: Horn Loaded woofers
Current Time: Fri Nov 13 06:02:00 CST 2026
