Home » Audio » Speaker » Dedicated horn loaded mid -- big disappointment.
Re: Dedicated horn loaded mid -- big disappointment. [message #61172 is a reply to message #61170] Mon, 12 October 2009 22:03 Go to previous messageGo to previous message
noviygera is currently offline  noviygera
Wayne,
This horn is used 200 to 800Hz. Seems this is an appropriate range for it. However, compared to a simple open baffle 10" driver, used in exactly the same frequency range sounds much cleaner, more natural.
I was very surprised, I thought the midbass horn would be much better in this application (what it was made for) but it doesn't. It must be a problem in the driver ( JBL e120 ) or the horn enclosure. But which is the problem?
Something tells me that the 12" JBL e120 is a driver made for loudness -- not clarity or articulation. Could this be it?
-Herman
Previous Topic: second array already in the works
Next Topic: Slot loaded woofers
Current Time: Fri Nov 13 06:30:02 CST 2026
