Wayne Parham Messages: 19105 Registered: January 2001
Horns are bandpass devices, rarely covering more than two octaves and almost never more than a decade. So you'll definitely need a woofer below and tweeter above. Also, horns don't work well with just any driver. A horn and driver should be matched for best performance.
When this horn is used in the right system, I would expect it to sound pretty good. But to know how to set it up, you'll need to do some work. Measurements would be helpful.
