Home » Audio » Speaker » second array already in the works
Re: second array already in the works [message #61157 is a reply to message #60711] Sun, 11 October 2009 22:29 Go to previous messageGo to previous message
Villain3g is currently offline  Villain3g
I haven't forgotten about my line array dreams. I've been weighing options like cost and complexity.
I was wondering about the length of the tweeter line. A line of 32 modified Tang Band 13-1264SA would only be about 26.5". I was considering doubling that number to 64 tweeters per line. That would make the line closer to 53". Would this provide a noticeable pushback of the far-field transition? If so, then it might be worth the investment.
I'm also interested in bi-amping with an active crossover. Is that an active crossover in your setup Eric? Does it perform to your liking?
The Tymphany TPY04WO4O0016 are a 4" woofer that head down to 66hz. They should be able to meet up with my subs. Their flanges will allow for 4-3/16" spacing, sufficient for crossing them at 3khz.
So, my setup as of now looks like 32 or 64 tweeters and 16 woofers per channel, bi-amped with an active crossover crossed at 3k.
The drivers are going to come to about $1k... I guess that's on the low end of the spectrum for line arrays.
32 tweeters per line will get me down to about $720.
What say you?
Previous Topic: Comb Filtering Misconceptions
Next Topic: Dedicated horn loaded mid -- big disappointment.
Current Time: Fri Nov 13 07:30:46 CST 2026
