Home » Audio » Speaker » Why does Selah find this to be true?
Re: Why does Selah find this to be true? [message #61113 is a reply to message #61112] Wed, 30 September 2009 07:56 Go to previous messageGo to previous message
Marlboro
Of course....
The actual point is somewhat less important than the slope of the cross, the symmetry of the cross, and the characteristic acoustic or electrical.
Traditionally when one(not to imply that the "one" is Selah) is using 6.5 - 8 inch woofers with a ribbon one has been forced to cross in the vicinity of 1200-1600 hz.
When one is using 3 inch wide range speakers, one can raise the cross point substantially to something above 2300 or more. Of course everyone should know that this ALWAYS entails the use of a woofer system to go with it since the 3 inch wide range just won't go low enough even with equalization, electronic crossovers, and a high power amp. You can't get a lot of water from a stone, some but not a lot.
Previous Topic: Symmetrical and asymmetrical slopes in crossovers
Next Topic: Comb Filtering Misconceptions
Current Time: Fri Sep 25 21:12:13 CDT 2026
