Sponsored
2-Pi tower bracing
(inside the box)
Re: 2-Pi tower bracing
message #61094
is a reply to
message #60995
Tue, 29 September 2009 16:23
Shane
May 2009
Wayne-o wrote on Wed, 23 September 2009 17:50
Does the 2x3 bracing go horiz. or vertical or put another way, if you look down the box from the top is the bracing 3 inches across or 2 inches across ? Thanks.
Wayne-o, here is what I did with mine, FWIW.
(Size: 40.74KB, Downloaded 3483 times)
(Size: 28.65KB, Downloaded 9083 times)
Message index
2-Pi tower bracing
By:
Wayne-o
By:
on Wed, 23 September 2009 19:47
By:
Shane
on Tue, 29 September 2009 16:23
By:
Wayne-o
on Fri, 02 October 2009 21:28
pi with tractrix
mid horn
Sat Oct 24 22:44:09 CDT 2026
