Home » Audio » Measurement » On axis measurements in nearfield listening (I don't experience this as an issue... maybe you do??)
Re: Measurement Information [message #61061 is a reply to message #61034] Mon, 28 September 2009 14:49 Go to previous messageGo to previous message
selahaudio is currently offline  selahaudio
jp wrote on Sat, 26 September 2009 02:29
I support Marlboro with his request ! Rick, Wayne , Jim, Danny , just hints that will help us as a start with array testing because as you mentioned Rick it is very rare to find info on that subject .
I also have TRUE RTA and a Bahringer ECM 8000 mic .
I will also go to Wayne's suggested forum but I'm sure all of us DIY's appreciate your guidelines , and be sure not to be afraid we wont be your competitors not even in 2 decades time ,ha ha ha .In the case some of you will help be sure you will attract more DIY and that can only be beneficial to all of you at the end of the road .You scratch my back I'll become your client , Hahahaha again .
JP
Start with the books I suggested. You need a good foundation in order to be able to understand the more advanced concepts. There's also no substitution for doing your own investigation - trial and error is part of learning the trade. I basically taught myself because I had the same limited resources that you do.
Previous Topic: What are the differences of the sound when using different isolation transformers?
Next Topic: O Scope
Current Time: Fri Oct 16 16:23:49 CDT 2026
