Home » Audio » Speaker » New sale price on a Vifa 3.5 incher
Re: New sale price on a Vifa 3.5 incher [message #61052 is a reply to message #61020] Mon, 28 September 2009 10:49 Go to previous messageGo to previous message
selahaudio is currently offline  selahaudio
darkmoebius2 wrote on Thu, 24 September 2009 20:11
Marlboro wrote on Thu, 24 September 2009 18:18
FR is +/- 2 db from about 80hz to 8500hz
That would be an awesome candidate if it really holds up to that graph. But, the Madisound page says - "Suggested box: 2 to 5 liters sealed and stuffed for an F3 of about 125Hz"
Wouldn't that suggest a crossover point around ~200-250Hz?
Any ideas how would that affect bass integration?
Th Fs is a little too high for a woofer array but it may work ok with an extended bandwidth subwoofer. A better choice is the 4" Tymphany woofer at Parts Express (#299-266).
What I would suggest is buying one to test and then you can determine where it should cross. With an array you have more flexibility because the driver isn't being pushed as hard; however, the phase shift still affects the integration with the sub.
Previous Topic: Line array differences: small vs large mids
Next Topic: Line arrays: 3 way(4 way) or two way
Current Time: Sun Nov 08 23:24:26 CST 2026
