Home » Audio » Speaker » Last Sunday
Re: Last Sunday [message #61048 is a reply to message #61041] Mon, 28 September 2009 06:01 Go to previous message
Your question is hard to answer because you're comparing two variables: point source verus line array and active crossover versus passive. I can't answer the crossover issue, but if you were considering driver cost alone, based on my experience I would agree with Rick's initial response to your post:
"It really depends on what your objectives are and what qualities you want in your system. With an array you're spreading a limited budget over several drivers versus just a few for a point source. The largest differences will be in tonality, sensitivity, and soundstage. The point source will have better tonality, especially if it's a 3-way. The array will give you a larger (and in my opinion) more lifelike soundstage with higher sensitivity.
Personally if it's under $1,500 in drivers I tend to prefer a point source because tonality is important to me. Even in the $2500-$3500 range you may find you favor a point source but the arrays do have the edge in dynamics as well. If you can go listen to a set of arrays and decide for yourself"
My experience as the owner of a Linus II line array using ten Vifa TC-series 5.5" woofers and eight Dayton PT-2 tweeters vesus a 2.5-way using Scan Speak Revelator drivers confirms this. The point source speaker using the $200+ drivers runs circles around the line array using $30 drivers in every way except for sensitivity and dynamics. Both speakers are Selah Audio designs, so the designs are equally competent or incompetent depending on your point of view. Laughing
Previous Topic: Widerange midwoofers, specs, and x-o pts...
Next Topic: Line array differences: small vs large mids
Current Time: Sun Nov 15 06:31:11 CST 2026
