Home » Audio » Speaker » Crossover Question about building line arrays
Re: Crossover Question about building line arrays [message #60939 is a reply to message #60892] Mon, 21 September 2009 08:21 Go to previous messageGo to previous message
selahaudio is currently offline  selahaudio
Active crossovers give you more flexibility but regardless of what you use being able to measure the result is paramount to having optimal performance. If you're using tweeters with lower sensitivity (domes and some planars) the active crossover will help you balance the output of the lines. Passive crossovers for arrays can be difficult to design and for most DIY's a good kit designed by a pro or access to an active DSP crossover is your best option. I advise against a non-DSP crossover because they typically only have symmetrical slopes and little ability to contour the response for baffle step and driver anomalies.
Previous Topic: Bose Line Array
Next Topic: Widerange midwoofers, specs, and x-o pts...
Current Time: Wed Nov 25 15:13:28 CST 2026
