Home » Audio » Speaker » Why would I not? (Trying to decide reference system over a line array)
Re: Why would I not? [message #60938 is a reply to message #60934] Mon, 21 September 2009 08:10 Go to previous messageGo to previous message
selahaudio is currently offline  selahaudio
It really depends on what your objectives are and what qualities you want in your system. With an array you're spreading a limited budget over several drivers versus just a few for a point source. The largest differences will be in tonality, sensitivity, and soundstage. The point source will have better tonality, especially if it's a 3-way. The array will give you a larger (and in my opinion) more lifelike soundstage with higher sensitivity.
Personally if it's under $1,500 in drivers I tend to prefer a point source because tonality is important to me. Even in the $2500-$3500 range you may find you favor a point source but the arrays do have the edge in dynamics as well. If you can go listen to a set of arrays and decide for yourself.
Previous Topic: transparency
Next Topic: Tweeter Options for Line Arrays
Current Time: Tue Nov 26 18:35:23 CST 2024
