Wayne Parham Messages: 19103 Registered: January 2001
No change in crossover components over time (if you use modern polypropylene capacitors) but the woofer does change as it ages. When first out of the box, it is tight and the system is slightly underdamped as a result. A few cycles at full excursion loosens them up, or several cycles at lower power. If you're careful, you can move the cone by hand instead of waiting for break-in from a flea-power amp.
