Home » Audio » Speaker » Help with Potential Line Array Project
Re: Help with Potential Line Array Project [message #60850 is a reply to message #60846] Sat, 12 September 2009 11:29 Go to previous messageGo to previous message
Marlboro
Mayhem,
The line array is workable but would entail more than you want to do, I should like. You need to either spread out the mids or get more of them. You would need a could of Foster super tweeter horns which have a 108 spl at 322 bucks a piece. You would need a Beringer crossover so you could cross from the mids at about 5000 with a 48 or 72 db/octave crossover. You would need to angle the system to avoid issues with angle dispersion.
It could work but I think its more than you want to do. And your other choice would probably be as effective, especially since you want it mostly for HT, not listening to Schubert or Beethoven symphonies.
Marlboro
Previous Topic: Play it again Sam: Share about your line array!
Next Topic: Fitting line arrays together
Current Time: Thu Sep 24 23:39:30 CDT 2026
