Home » Audio » Speaker » Fitting line arrays together
Re: Fitting line arrays together [message #60823 is a reply to message #60806] Thu, 10 September 2009 14:56 Go to previous messageGo to previous message
darkmoebius2 is currently offline  darkmoebius2
Audience has taken an interesting approach to the HF issue by designing their own 3" fullrange A3 driver(.pdf spec sheet). Their arrays are complemented by subwoofers for the bottom octaves.
Anyway, their A3 drivers have a natural 3-5 dB rise between 1.5kHz and 7kHz, above that it is +5-15dB out to 20kHz. They supposedly run their arrays fullrange w/o any crossover. And the drivers are 85dB/16ohm w/ 12mm of excursion.
My question is if the natural HF rise in their A3 compensates for comb filtering effects as a result of c-to-c distances?
index.php?t=getfile&id=63&private=0
  • Attachment: a3.jpg
    (Size: 70.55KB, Downloaded 4064 times)
Previous Topic: Help with Potential Line Array Project
Next Topic: What about Oval shaped drivers (like 4"x6") for arrays?
Current Time: Sun Nov 08 22:22:22 CST 2026
