Home » Audio » Speaker » second array already in the works
Re: second array already in the works [message #60748 is a reply to message #60744] Wed, 02 September 2009 07:48 Go to previous messageGo to previous message
Marlboro
I chose to put each mid in its own separate enclose to eliminate any interaction in the back wash of sound. Additionally I didn't want any sound coming back through the front of the speaker to muddy the midrange, thus the 22.5 inch SEALED tubes stuffed with fiberglass TO A 4 lb/cu foot density, and wrapped in polyfill batting to keep the fiberglass strands out of the speaker itself.
Also using tubes you have no odd order harmonics in the back wash due to the characteristic of propagation of sound in a closed tube. This means that any sound that might come through will be clarifying sharp even order harmonics. There will be no harmonic distortion since each speaker only handles 6% of the total sound per channel. Each one never plays loud enough to distort in any way.
Its a little know fact that even inexpensive speakers will perform at high QUALITY levels when their volume is turned down low. its when they are required to play above 3 watts that they start to sound badly when they are inexpensive.
Marlboro
Previous Topic: Comb Filtering Misconceptions
Next Topic: Dedicated horn loaded mid -- big disappointment.
Current Time: Fri Nov 13 09:03:58 CST 2026
