Home » Audio » Speaker » second array already in the works
second array already in the works [message #60711] Sun, 30 August 2009 23:45 Go to previous message
Villain3g is currently offline  Villain3g
After checking out the recommended reading... I've decided to make my next line array a 2 way setup, crossed around 3k. For the woofers I'd like to use 8 Vifa BC14WG79-08's. They should go low enough to meet up with my subs. My question lies with the tweeters. My plan is to modify the flanges on the Tang Band 13-1264SA it looks like the inner structure is 30mm. If I remove the entire flange, will this get the c-to-c close enough?
Previous Topic: Comb Filtering Misconceptions
Next Topic: Dedicated horn loaded mid -- big disappointment.
Current Time: Mon Nov 30 11:06:15 CST 2026
