Home » Audio » Speaker » Crossing near Fs
Re: Crossing near Fs [message #60468 is a reply to message #60466] Sat, 25 July 2009 13:48 Go to previous message
I use the fs number as a rough guideline for the bottom end of the passband, but that's really all it is. The behavior of the system depends not only on the free air resonance of the diaphragm but also on the loading. Horns load the driver more than reflex or transmission lines, each of those load the driver more than a sealed box or infinite or open baffle. There is also the application, in that if you're pushing these things hard you may exceed the limits and increase distortion or possibly even damage the drivers. But if you're not pushing them so hard, you can probably go lower with them. To be sure, run some tests and arm yourself with hard measurement facts. That's the best way to make a decision.
As for the Qts value, what that means is the system the drivers are loaded in must load the cone appropriately or you'll have some peaking near resonance. I would expect it to work best in a very large box (compared to Vas), or possibly an open baffle. You can use modeling tools like BoxPlot or Hornresp to predict response.
Previous Topic: AE TD12S
Next Topic: Re: Diffraction absorption in my line arrays
Current Time: Sun Oct 25 11:57:32 CDT 2026
