Audio
how to use a multimeter when installing car audio system?
Re: how to use a multimeter when installing car audio system?
message #59832
is a reply to
message #59801
Mon, 06 July 2009 00:46
euphonics
July 2009
You can check the ground using this link...
http://www.the12volt.com/installbay/forum_posts.asp~TID~49445~PN~1
You can set your gain by using these links...
http://mobile.jlaudio.com/support_pages.php?page_id=143
http://www.thesuicidaleggroll.com/gain.htm
You can check the voltage at an amplifier by measuring across the power and ground cable. It should be around 13-14.4 volts at the amp when the car is running.
Good Luck!!!
Message index
By:
audiophile
on Mon, 06 July 2009 00:15
By:
music
on Mon, 06 July 2009 00:42
By:
euphonics
on Mon, 06 July 2009 00:46
Can you Help? Audio amp wire routing.?
Welcome to Crescendo Systems!
Thu Nov 05 13:38:06 CST 2026
