Home » Audio » Speaker » Need suggestions for a lower range horn to mate with new Mid/High horns
Re: Two midbass horn layouts... [message #59566 is a reply to message #59565] Tue, 30 June 2009 22:08 Go to previous messageGo to previous message
noviygera is currently offline  noviygera
So, Wayne, do you believe any of the two options would work? I couldn't figure out if you are against both options, in which case I assume I would have to mount the midbass, between the highs and subs. Please clarify.
Thanks,
Herman
Previous Topic: using a wall of 15" woofers for bass.
Next Topic: Maggie in High Heels
Current Time: Sun Nov 08 12:25:14 CST 2026
