Home » Sponsored » Pi Speakers » Help please ... from the bottom up (Four Pi questions)
Re: Help please ... from the bottom up [message #59557 is a reply to message #59556] Tue, 30 June 2009 10:06 Go to previous messageGo to previous message
The size and weight of the two π tower kits isn't a problem. They're 20 pounds each, and we'd send them in two separate boxes to avoid size restrictions.
The weight of the four π kit varies, of course, depending on options, but it's about 60 pounds. I suggest JBL 2226 and DE250 options, and I'd use the larger 15 guage coils.
The size restriction really hurts us here, if we go with parcel post. You can't quite get all the stuff needed in one box, so you have to send the woofer separately. My suggestion would be to source that locally. See if you can find the JBL 2226H. I can send the rest at a reasonable cost.
Previous Topic: Please post pictures of Four Pi Pro
Next Topic: 4PI plan with JBL 2227 & Altec 909-8A on 811B
Current Time: Thu Oct 15 15:56:00 CDT 2026
