Home » Audio » Speaker » Need suggestions for a lower range horn to mate with new Mid/High horns
Re: Need suggestions for a lower range horn to mate with new Mid/High horns [message #59525 is a reply to message #59524] Thu, 25 June 2009 17:58 Go to previous messageGo to previous message
noviygera is currently offline  noviygera
I see your point, Wayne, thanks for replying. I will do some measuring and post sketches of two more options I thought of.
In brief, one idea is to mount the midbass above the mid/high right under the ceiling (touching the ceiling), horn loading the ceiling from 150 to 600 Hz.
The other (coaxial) is to make the midbass horn large enough to accomodate the midhigh horn inside being offset from the midbass center vertically. So the midhigh will be inside the midbass, but above the throat level of the midbass, leaving the midbass driver unblocked from view. But this would, make it unnecessarily wide dispersion vertically.
Previous Topic: using a wall of 15" woofers for bass.
Next Topic: Maggie in High Heels
Current Time: Sun Nov 08 12:25:15 CST 2026
