Home » Audio » Speaker » Mid to Woofer crossover frequency selection
Re: Mid to Woofer crossover frequency selection [message #59375 is a reply to message #59373] Sat, 13 June 2009 11:17 Go to previous messageGo to previous message
Subwoofers act differently indoors than they do outdoors because of room reflections. Outdoors, it makes sense to position sound sources so they combine constructively, within 1/4λ at the crossover point. Indoors, this doesn't work because boundary reflections make that impossible unless the room is very large, like an auditorium.
You will have interference nodes at certain frequencies below the Schroeder frequency of the room, typically around 200Hz. The best thing you can do for low frequencies indoors is to spread sound sources around, creating dense interference to smooth the overall sound field. Do a search here for "multiple subs", and study the principles for some good ideas how to setup your system.
Previous Topic: pipedreams 21s cost to build?
Next Topic: Salvaging my misguided array Help Fred
Current Time: Thu Nov 26 09:25:54 CST 2026
