Home » Audio » Speaker » Open Baffle Visaton B200 & Eminence Delta (Behringer DCX2496 Xover setting)
Open Baffle Visaton B200 & Eminence Delta [message #59351] Tue, 09 June 2009 03:28 Go to previous message
benzene is currently offline  benzene
I just completed an open baffle project. But it doesn't sound right. Especially some prominent echo on the mid high freq and mid high freq is quite bright.
My baffle dimension is 20" x 52", with 2" thickness. The configuration on each side is:
1 pc Fountek NeoCD2.0 Ribbon Tweeter
1 pc Visaton B200
2pcs Eminence Delta 15A
I'm using Behringer DCX2496 active crossover, running 2 ways, tweeter & B200 1 way coupled by capacitor of 1.22uF & 2pcs Delta another way.
Attached photos for your reference.
Would like to ask what type of crossover to use, which order, what freq to cross at & other essential setting to look at?
Or is it due to other factors, like driver or room?
Need advice.
Thanks.
index.php?t=getfile&id=19&private=0index.php?t=getfile&id=20&private=0index.php?t=getfile&id=21&private=0
Previous Topic: Any decernable results from round over at mouth of horns and cabinet edges?
Next Topic: Q for AudioFred
Current Time: Sun Nov 29 04:15:53 CST 2026
