Home » Sponsored » Pi Speakers » 7 Pi treble edge! (How to try and reduce this?)
Re: 7 Pi treble edge! [message #59344 is a reply to message #59342] Thu, 04 June 2009 18:09 Go to previous messageGo to previous message
PaulW is currently offline  PaulW
Here's a quick look round the room - Should have tidied up!
Front with small bass traps in top corners and behind mid horn. I was going to get a taller pair as these worked really well.
http://i142.photobucket.com/albums/r81/4will8/IMG_6899.jpg
To the right, with rugs and foam damping panel
http://i142.photobucket.com/albums/r81/4will8/IMG_6896.jpg
To the Rear, with foam cubes in top corners and rear panel.
http://i142.photobucket.com/albums/r81/4will8/IMG_6897.jpg
From your earlier response I should get the bookcase out from behind my seat?
And to the left with large glass sliding door and window
http://i142.photobucket.com/albums/r81/4will8/IMG_6898.jpg
I have some wedge foam tiles which I was going to make two 45 inch, square panels for the ceiling.
Previous Topic: How to use code?
Next Topic: Finished Pi 4 with photos
Current Time: Mon Oct 12 19:27:12 CDT 2026
