Home » xyzzy » Dungeon » I don't have any cartoons; any have anything interesting?
Re: Vinyl [message #58180 is a reply to message #58179] Mon, 03 April 2006 18:44 Go to previous messageGo to previous message
If you have a removable stylus; not a moving coil cart; you just pull the stylus out then with a toothpick you take small drops of that blue adhesive they use to secure poly windows to the frame in RV's and line it along the plastic perimeter of the stylus; the part that touches the body of the cartridge. Then just gently replace the stylus so the adhesive bonds the stylus to the cart body. Let it cure then you get a much better bass/tighter detail better information recovery. It really is like buying a more expensive cartridge. They say it damps resonance; create a tighter mechanical bond and adds mass. Whatever it does; believe me it works.
( Although I wouldn't try it on my 1k$ Shelter 901.) ( Thats if I had one; or could afford one.)
Which Technics do you have?
Previous Topic: Protests March For Immigration Reform
Next Topic: Hiking today
Current Time: Wed Nov 04 22:00:19 CST 2026
