Home » xyzzy » Tower » Found it
It's a misleading chart. [message #55247 is a reply to message #55244] Thu, 11 May 2006 08:25 Go to previous messageGo to previous message
Mr Vinyl is currently offline  Mr Vinyl
First off it shows the deficit going up under Carter but arrows show it going down. Plus it's blown out of proportion by it's scale. Look at the chart above. It's much more in prospective and shows the debt going on an upswing starting around Nixon to present (Not too convinced this chart is accurate either). Only slight bumps here and there. As I said before, and I believe you agreed with, this is mostly do to the economy and has nothing to do with the President. That said I agree with you that both parties are spending too much. But Reagan had to rebuild the military (money well spent in my opinion) and GW Bush has had a war, a terrorist attack (911 - no small bash to the economy)and what 3 or 4 hurricanes disasters?. Yes these have all made a difference. These were not small expenditures. The debt raised under Clinton's first term and only came down during his last term. Maybe the same will happen for Bush. I believe it will as the economy picks up again. We'll see.
Also one must consider where the money is being spent and conditions at the time.
Again, I'm not making excuses. Spending has to be cut. I have no hope in that happening. Do you? So to answer your original question. Which would I prefer Tax and Spend liberals or Borrow and spend Republicans. They both are the same. Both end up causing a crisis eventually.
Previous Topic: Public Debt, Not Bad..People borrow to buy stuff like houses. Deficit..VERY BAD! The govt Spends Mor
Next Topic: I see; so we are all fans of deficit spending
Current Time: Tue Sep 29 04:58:06 CDT 2026
