Home » xyzzy » Tower » Qucik Tips on Better Photos
Qucik Tips on Better Photos [message #54315] Mon, 27 June 2005 13:11 Go to previous message
I love the fact that a lot of guys on this forum share photos of their projects. Pictures are worth a thousand words, right. So I thought I'd post some simple tips on how to get better indoor shots of your projects for posting:
1) Take the light source off your camera. Direct light source from the camera creates glare, center hot-spots, and general flatness to a picture. If you're using a flash with tilt or swivel, bounce it off the ceiling or walls. If you're using a digital point-n-shoot, switch the flash off and place a light source (a lamp) off the camera. Even better is to have a lamp on one side of the object and a large white card on the other.
2) Use a tripod or rest your camera on a support. Once you switch the flash off and use a lamp or existing lighting, your camera will go to slow shutter mode (unless you're working with 500W studio lamps). Hand-hold the camera and you'll get blurry shots. Use a tripod, or rest it on a support and it'll sharpen right up.
3) Manually set your white-balance. The auto white-balance on most point-n-shoot are pretty good, but are still prone to error. If you're shooting with indoor lighting, manually set the white balance to Tungsten. Photos with an orange colour-cast are a result of shooting with indoor lighting while your camera still thinks it's outdoors.
4) Use the Macro function if you're closer than one (or even two) feet from the object. Most point-n-shoot can't focus under a foot under normal focus mode. Switch on Macro and you're good down to 6 inches. Always use Macro when shooting small objects.
gar.
Previous Topic: P2P supremes rule
Next Topic: Eminent Domain/Democracy
Current Time: Sun Nov 15 22:07:34 CST 2026
