Home » Sponsored » Pi Speakers » How high does the pi 7 bass horn go?
Re: How high does the pi 7 bass horn go? [message #53537 is a reply to message #53536] Wed, 13 May 2009 19:35 Go to previous messageGo to previous message
Yes, it will reach that high. The thing is, above a couple hundred Hertz, the walls start to act as reflectors. This makes a few blips in the response curve from self-interference with the boundaries. When you look at averaged response, you can run the woofer way up high but a high-resolution plot will show self-interference notches above 300Hz.
Previous Topic: Active Theater 4 Bi-Amping
Next Topic: Any new horn flares to work with midhorn?
Current Time: Sat Nov 07 01:33:08 CST 2026
