Home » Sponsored » Pi Speakers » 2-Pi tower port size???
Re: 2-Pi tower port size??? [message #53525 is a reply to message #53522] Tue, 12 May 2009 17:14 Go to previous messageGo to previous message
If you measure it, you'll find it resonates around 40Hz to 42Hz, somewhere in there. I've seen some Helmholtz calculators that show values a little higher, some a little lower. Mostly I think it's the difference in the area offset, sometimes called "corrected length". If you try two or three different calculators, you'll see what I mean.
The tower two π is a little trickier than some bass reflex cabinets in that standing waves are developed within the passband. That makes port and driver location pretty important. It also makes the insulation even more important than usual, so be sure to install it as described in the plans.
Previous Topic: "Crossover Electronics 101"
Next Topic: 2Pi Towers - larger cabinet size-Wayne can you help?
Current Time: Thu Nov 05 12:28:06 CST 2026
