Home » Sponsored » Pi Speakers » Active Theater 4 Bi-Amping
Re: Active Theater 4 Bi-Amping [message #53523 is a reply to message #53521] Tue, 12 May 2009 16:52 Go to previous message
Yes, that's a good way to split them out. It would be pretty easy to amp the woofer separately from the mid/tweeter in a π cornerhorn. Same idea as the sub/mains split I mentioned in the last post. That way you keep the passive crossover that's used in the mid/tweeter region, because it is already optimized and might be hard to duplicate with off-the-shelf crossovers.
Previous Topic: Speaker over damping !!!
Next Topic: How high does the pi 7 bass horn go?
Current Time: Wed Nov 18 00:33:34 CST 2026
