Home » Sponsored » Pi Speakers » LAB12 driver - why is it so good and efficient?
Re: Electro-mechanical properties and diaphragm motion [message #53437 is a reply to message #53434] Sat, 18 April 2009 06:09 Go to previous messageGo to previous message
adamzuf is currently offline  adamzuf
Wayne,
Thank you for such a detailed answer.
"Electrical damping is almost always an order of magnitude greater than mechanical damping"
Sorry I don't understand the expression (English ain't my first language)
"The difference is that in the pistonic range, the forces required to bend the diaphragm are small enough that it operates as a rigid piston. "
Is that because higher frequencies are smaller to "fit" into the diaphragm and push it into the non pistonic range? (smaller driver = higher frequency of cone breakup)
"usually if the cone is made stiffer, it tends to breakup later but harder."
I assume you meen "higher in frequency?"
So, as I gather from what you are saying, the damping of the system loses control over the cone's independant motions, and one can not tell from thiele/small parameters the properties of the non pistonic range at all..?
This is great info. Thank you.
Adam
Previous Topic: 2π Tower plans
Next Topic: 3 pi plans
Current Time: Sat Oct 31 10:42:45 CDT 2026
