Home » Sponsored » Pi Speakers » LAB12 driver - why is it so good and efficient?
Re: LAB12 driver - why is it so good and efficient? [message #53420 is a reply to message #53419] Mon, 13 April 2009 14:45 Go to previous messageGo to previous message
The resonant frequency shifts when you put the woofer on the horn, with the front chamber and flare shifting it downwards and the rear chamber shifting it upwards. When you model the horn and modify electro-mechanical driver values, you'll find that lighter cones increase output mostly at the top end, not at the bottom end.
It's all about what you want to do. If you want a midbass horn, use a lighter cone, by all means. It will give better output up into the midrange. But if you're looking for drivers to use in a hornsub, you probably wouldn't need (or even want) the HF extension. For a subwoofer, I would prefer a driver that does its best work down low and is robust enough to handle high excursion and current.
Previous Topic: 2π Tower plans
Next Topic: 3 pi plans
Current Time: Sun Nov 08 05:18:37 CST 2026
