Home » Sponsored » Pi Speakers » B&C DE 250 and compensation
Re: Speaker setup [message #53403 is a reply to message #53402] Thu, 09 April 2009 10:28 Go to previous message
Actually, the cabinet volume is fine for the 2226, it's the Helmholtz frequency that's wrong. The three π and four π speakers are slightly different size, but either could be used as long as the port was right for the woofer chosen. So you would need to change the port if you changed the woofer.
The problem is it's hard to resize a woofer hole and/or port and do a good job. You're limited on the tools you can use. So I understand your dilemma. Sorry, but I know of know drop-in replacement woofer you can use for an upgrade to your three π speaker. Might be worth looking at AE Speakers, to see if they have a woofer or can make one for this application. On first glance, the TD-12S specs look right.
Previous Topic: Auricap upgrade
Next Topic: 80 hz punch
Current Time: Mon Nov 23 09:35:22 CST 2026
