Home » Sponsored » Pi Speakers » 6Pi - 7Pi bass cab same dimensions?
Re: You may now graduate to finger-painting [message #53286 is a reply to message #53284] Tue, 03 March 2009 05:00 Go to previous messageGo to previous message
PaulW is currently offline  PaulW
To mount the HF horn I would use a "T" shaped platform attached to the front/top of the horn in-line with the original dimensions, supported by the triangular brace. A similar method below to support the mid on the bass unit. Still all a bit academic at the moment as these are just ideas in my head and on the doodle pad!
Don't remember any posts about altering crossover points TBH, the end result with mine is impressively cohesive as it stands - I certainly can't hear the joins ;¬)
Paul
Previous Topic: 7pi XO points
Next Topic: plans for Pi 4
Current Time: Fri Nov 27 05:05:42 CST 2026
