Home » Sponsored » Pi Speakers » How Do I Connect Speaker Wire To These Spades?
Re: How Do I Connect Speaker Wire To These Spades? [message #53067 is a reply to message #53065] Sat, 10 January 2009 14:45 Go to previous messageGo to previous message
breakfastchef is currently offline  breakfastchef
I posted this same question on another DIY forum and I was told they are compression spades. Apparently you thread the wire through the removable section of the barrel and fold back the ends of the wires. Then screw the removable section into the spade for a tight compression fit.
Though, using solder, I can be assured the wires are making good contact.
Previous Topic: Enclosure volume.
Next Topic: Three pi subs 92 db ?
Current Time: Tue Nov 24 17:43:30 CST 2026
