Home » Sponsored » Pi Speakers » 4pi: floor mount or stand mount? / plans needed
Re: Positioning and subs [message #53053 is a reply to message #53052] Wed, 07 January 2009 01:14 Go to previous messageGo to previous message
Rocketmail is currently offline  Rocketmail
Thanks, Wayne, for the informative answer and suggestions. The tilted base is similar to the Klipsch Heresy bases available when I used those speakers, although I actually mounted the Heresys on boxes and placed them in corners. Experimentation is the key-- and as you say, the speakers must be built first.
I am definitely going to try multiple subs, having followed the discussion concerning them by both you and Earl Geddes. I have assumed that corner mounted woofers with a time-aligned playback above 250hz or so was the best possible (ala TacT/Lyngdorf)-- but that may not be the case below Schroder frequencies.
Thanks also for the various plans. I admire your approach to bringing good sound to the non-engineers (includes me)-- and your "good value" approach.
Time to get some enclosures built.
Mark
Previous Topic: Subwoofer Recommended for 2 Pi Towers?
Next Topic: experience with compression drivers.
Current Time: Sun Nov 08 14:00:53 CST 2026
