Home » Sponsored » Pi Speakers » JBL 2446 & 2226 in a Corner Horn Design
Re: JBL 2446 & 2226 in a Corner Horn Design [message #53014 is a reply to message #53012] Fri, 26 December 2008 11:40 Go to previous messageGo to previous message
I've used the 2206 as a midbass driver, and it's a great part but won't work properly in the π midhorn. You probably can find a JBL 2012 or 2123 in good shape, and those work well. As for compression drivers and horns, I suggest going with JBL 2426 if you want a speaker with all JBL drivers. The 2226/2012/2426 combination is very nice.
The problem with using the large format driver isn't just the fact that the larger driver doesn't have quite the HF extension. Even if that weren't the case, the horns used with them are necessarily different sizes too. The geometry is wrong for the existing crossover, so you would have to redesign. I've gone to great lengths to set the crossover points right so directivity is uniform at the crossover points and the null angles are outside the pattern. That's not a trivial task.
Previous Topic: What solid filler for Theater 4 cabs...
Next Topic: 2 Pi Tower Pics - Any Problem With My Design?
Current Time: Mon Oct 19 17:34:19 CDT 2026
