Home » Sponsored » Pi Speakers » EV SP15B in Pi 4 ???
Re: EV SP15B in Pi 4 ??? [message #52905 is a reply to message #52903] Wed, 26 November 2008 22:32 Go to previous messageGo to previous message
James is currently offline  James
Wow, what a great resource -- thanks for the link!
I'm probably wrong, but the limited literature I've been able to find on the EV SP-15B indicates that it's closer to the SP-15, both with whizzer cones, ceramic mags, stamped-steel baskets, and intended for hi-fi use. The SP-15 even had a midrange/treble control. The SP-15A has a cast basket, and an Alnico mag (I think).
You may well be right that there is little difference among them, but in one piece of EV lit I found regarding the SP-15B, it was suggested that it's best use was in an infinite baffle. If I understand that application correctly, which I probably don't, then it might be that the SP-15B has a much higher Qts, making it a very different animal.
I think I'm going to get that woofer tester from PE.
Thanks again for the link ... I found info on several other speakers I was having trouble finding.
Happy Thanksgiving to all!
Best,
Jim
Previous Topic: ke-33 woofer !!!
Next Topic: Oy! I'm stuffed!
Current Time: Fri Nov 06 08:04:55 CST 2026
