Home » Sponsored » Pi Speakers » "Bill Epstein" cabinet building details?
Re: "Bill Epstein" cabinet building details? [message #52841 is a reply to message #52840] Sat, 01 November 2008 18:52 Go to previous messageGo to previous message
I just used butt joints since I was going to veneer with marine-type plywood, Arauco, from Lowes, about $38 a sheet.
I kept the bracing to a minimum with just 1 plywood window pane which helps square the box and a few pieces of pine 1x4 placed irregularly on the walls. The Arauco seems quite non-resonant and I wanted to try the Audio Note idea of letting the box flex somewhat.
The multi-layer approach you mention is well-regarded; the XLH was built from 3- 3/4" layers and we know how natural that sounded. And how heavy!
If you use plywood and no veneer cutting 45s and joining with biscuits then using a few band clamps is a great idea. Personally, I don't think all the box-within-a-box stuff is worth the trouble, but that's just me.
Previous Topic: 3pi/4pi plans? Horn lens question
Next Topic: Pi 3 plans please?
Current Time: Tue Nov 03 06:48:16 CST 2026
